Is there any chance that a Skip button could be added to the Get Folder Sizes dialog to skip over the specific folder that is currently being scanned? Sometimes it sits there for ages on a massive folder that I'm not interested in and it's laborious to stop it, remove that folder from the selected ones and do it again, especially if it does it again further down the list.
Thanks for the suggestion, we'll add this in the next update.
This is in 12.20.8.
12.20.8
Is there a NODIALOG switch for GetSizes ?
Looks a bit messy.
Automatic folder size calculation won't trigger a dialog.
Manual folder size calculation will, since the assumption is you want to know when it's finished if you trigger it on demand.
Thanks for that. I should have asked for it 10 years ago.
