most of the multiple buttons show the LMB/RMB/MMB tool tip correctly. However, i have a few buttons in use, which do not show the button content. If this is not possibly a mistake by me, this maybe would be worth to be looked at.
The buttons are, however, very normal buttons containing normal stuff, but maybe it´s helpful, if i describe them. The examples show actually the LMB entry (tool tip showing name only, no LMB comment), but the other functions are visible in customize mode only.
1.: "actualize" (Go REFRESH=all) / Go Autostart (Go %path)
2.: make new dir, with name=date / select similar
3.: toggle hidden / toggle *.xxx / toggle *.xyz
So there don´t seem to be an apparent reason, for this issue to occur.
Ah, easily fixed:
[ul][li]Put Opus in Customize mode.[/li]
[li]Right-click the Three-Button (i.e. the root item, not one of the Left/Right/Middle sub-items) and choose Edit.[/li]
[li]Remove the Tip string.[/li][/ul]If the root item has a Tip then that will be displayed instead of the tips for each of the sub-items.
[quote="nudel"]Ah, easily fixed:
[li]Remove the Tip string.[/li][/ul]If the root item has a Tip then that will be displayed instead of the tips for each of the sub-items.[/quote]
Yes, that did it! thank you. I filled that field in, assuming it´s needed in order to show the tool tip.
