Hi,where do you find your smart favourite
Hi, you can find it here:
https://www.gpsoft.com.au/help/opus12/index.html#!Documents/SmartFavorites.htm
https://www.gpsoft.com.au/help/opus12/index.html#!Documents/Prefs/smartfavorites1.htm
Click on this to open the menu containing Favorites and Smart Favorites (if any):
You can configure how Smart Favorites behave under Preferences / Favorites and Recent / SmartFavorites.
Please link your account in that case, so we know that for any future threads.
Are Smart Favorites turned on in Preferences? Have you done anything with any folders which would give those folders enough points to be added to the list, based on the configuration?
(I'm assuming all the folders in your screenshot were manually added to the Favorites list. If not, then those probably are your Smart Favorites.)
Now you have to use Directory Opus for a while. It will memorize the folders you use (very) often and will display them as SmartFavorites.
thank you
