Smooting of fonts
I'm wondering why text fonts used in the file display does not use font edge smoothing? I'm using the standard MS Sans Serif, but changing fonts doesn't help. Font smoothing is used everywhere else in DOpus' GUI. Even in the list of files found in the Find window. Is there some non-obvious place I should look?
DOpus x64
Win 7
Which fonts have you tried? MS Sans Serif and some other fonts seem to disable cleartype.
Try with Segoe UI.
MS Sans Serif disabling cleartype is confirmed here: damieng.com/blog/2006/04/10/clea ... ssansserif
Segoe UI did indeed work. Thanks, people!
