Sort order arrow in folder format dialog
atm there are sort order arrows in the folder format dialog when there is more than one column being sorted
Can we please have a sort order arrow that is CTRL clickable (to change direction of sort) when there is only one column being sorted.
Don't forget to link it with relevant options in the sorting tab :slight_smile:
The Sorting tab has an option to reverse the entire sort order, which is all you need when there's only one sort column.
Yes I know, but the request still stands as there are advantages to having the alternate sorting order option detailed above, viz
  • columns view is initial view when opening dialog and checking sort order when only one column is being sorted requires less clicks
  • likewise changing sort order is easier and requires less clicks
  • when opening dialog and seeing the sort order, the user is reminded that 'awsome file manager' can easily set and change sort order
put on list please
