I have looked around but not found anything on sorting on "natural order" in listers, that is, being able to disable ascending or descending sorting and move files and folders around by dragging. Is this possible?
Regards,
Hans L
Regards,
Hans L
Do you mean natural sorting (ie. test1.txt,test2.txt and then test12.txt), avaliable in folder options, or custom sort (like light table in graphic cataloging programs)- not avaliable?
X.
I meant custom sorting (sorry if I was not clear). Thanks for your reply.
Regards,
Hans L
Fill feature request via GPSoft support page to increase chance for custom sort to appear in next versions.
X.
