I do use my favorites a lot. Problem is that if I select a folder, the favorites move up and out of view. I am aware of options to keep the folders more condensed, but what I really would love to see is the option to split the favorites and folders into two panels like this:
You could put your favorites on a toolbar or menu to separate them from the tree. (They're in a menu on the file display border by default, but can be placed anywhere you want. You can also make individual shortcuts anywhere on toolbars if it's easier than using favorites.)
I secretely knew that it can be done. Putting my favs in a bookmarks bar like I am used to from chrome is even better. Keeps everything neat and tidy. dopus
