Split View, default path
I have an issue with the split view toggle command. Is there a way to make the second file display change it's default path to e.g. local drives (\mycomputer) instead of having the same path as the source?
I tried setting it manually, by going advanced mode and just doing:
Set DUAL=Toggle
Go E: OPENINRIGHT
This doesn't work at all, the display just flickers and returns to single folder mode.
I know I can just keep the second line and put it in a separate button, then use the toggle button to go back to single folder, so the question is, can I get the function with just one button or is the toggle command locked to always duplicate current lister?
/Anders, OnyxSoft
You probably want the Preferences / File Displays / Options / Specify initial folder when switching to dual file display option.
Ah, I guess I missed it since I was focused on looking for the word "path" when browsing through all the settings.
Thanks a lot =)
