Starting another Shell
Hello.
Is it possible to start another Shell instead of cmd.exe?
I am using PromtPal and I would like to open it when I type something in a lister search-field with a ? put in front.
You can use the %ComSpec% environment variable to change the command processor.
Hi Jon,
thanks for your reply but this does not work, because DOpus calls the command processor with /K. PromptPal does not know about this argument.
Edit:
I helped myself with a little Exe, that operates as command processor and calls PromptPal without the /K.
/K is only added if you have @leavedoswindowopen in the button.
It's not a button; it's the inline command field:
Oh, ok yes that goes through the @leavedoswindow command code as well. We'll look at changing this in the future.
Thanks a lot!
