Strange behaviour of file with pin to top label
File is pin to top only if file is display in window.
Look file stockcert.txt in capture.
Video_2018-01-24_211240.zip (337.0 KB)
Confirmed & thanks for reporting it. It may be a while before we get to this as it needs some thought on how to make the feature work better, possibly by storing the pinned information in a different place instead of using labels (since labels are not calculated until files are displayed), but we agree the feature isn't working right.
Thx Leo, I've also found this frustrating, and it has been nearly 3 years
since the bug was reported.
Can it be given some priority ?
Cheers, Brian
We have a fix but it's part of a larger overhaul of things which isn't finished or tested yet, so it'll be a while longer. Apologies.
Thx Leo,
any ballpark idea of when it will become available ?
Cheers, Brian
No, sorry. If i made a guess it would probably be wrong at this stage.
Hi Leo,
any update on this one ?
Cheers,
Brian
