Strange behaviour when clicking pulldown menu
Since DO9 when clicking a menu button (pulldown menu) with one click and moving directly to a command within the menu DO seems to make a "hidden second click" and execute a menu-command (depending where mouse was moved over before). This happens really often.
Example: Clicking on settings menu and moving down directly DO opens copy-filter-settings for example.
I really press the left mouse button only once a time. Also I didn't changed double click rate or something else. The mouse is ok, no other apps behave like this.
I suspect you're moving the mouse before releasing the button, after the first click.
Menus work in two ways. You can either:
[ul][li]Click (hold), move and release.
Or:
[/li]
[li]Click, release, move, then click again.[/li][/ul]If you are trying to do the second method but move the mouse over an item before releasing then you'll end up doing the first method and selecting an unwanted item.
Hmm, I will test this (am I too fast :wink:? But this never happened before :confused: )
I do that regularly.
