Add a little Filter Field to the Advanced Rename Dialog that works like the Filter Bar in the File Display.
Benefit: Makes finding presets easier when there are many presets, the screen is small, or the user doesn't remember the preset's exact name.
A filter for the presets themselves?
You can group them into categories which I find makes them easy to find even with a lot of them.
Yes, for the preset list. It's like in the Opus preferences or like using Everything despite having plenty of folders, sometimes this is simply the fastest way with the least amount of clicking and scrolling.
