I want it to keep focus on the lister that was currently focused, but it doesn’t do that. I can’t find the function to keep focus, I think this Tab function is “go swap”, but I need to add something to keep focus. ?
Also, is it possible to disable these “Tab Key” options so that we can put custom hotkeys on the Tab instead.
I had (Ctrl + Tab) and (Ctrl + Shift + Tab) set to prev/next tab on all my other programs, so that conflicts with this. So I am using Shift + Tab to switch listers, but it won’t keep focus.
For the tab switching, could you let us customize the hotkeys for that? So I don’t have to have Ctrl + Shift + Tab for the tab switcher.
Could you give us an option to make it sticky (you don’t have to hold in the tab key) and a little find box where we can start typing the name of the tab, and we can filter by time opened, and divided by lister. A handy tool that we can find tabs, if we have like twenty open. A recently closed tab would be nice too. We have the tabs rescue plugin, but still would be nice incorporated into this tab switcher. More of a tab manager.
So can we get a fyat on that? If I want to find my Drums tab quickly, I can just type d and it filters out the tabs to that. Can we get the tab edge colors on there too? plz plz
Also could you let us choose to make the tab switcher display the names of the tabs instead of the paths. We could hold down our tooltip modifier key and the paths would display instead.
