Switch to Light!
Switch to Light not working, After press OK nothing happens... I tried that uninstall old version 12.7 and install new version 12.8 and the same problem?
I did a quick test on a clean Windows install, and switching between Pro and Light works OK in 12.8.
When you say nothing happens after you push OK, what do you mean exactly? Does the dialog you click OK in close? Do the other program windows close and re-open?
Are other Opus settings changes which you make (e.g. via Preferences) saving OK, and surviving a reboot?
Thank you for your prompt reply, I'm so glad.
When I push OK, the restart message closes but the Directory Opus not restart and not switch to Light!
So I can't enter Opus settings
It says your evaluation has expired and dates back to early 2016. That's probably why it isn't working.
You can try Opus for free for 60-90 days (60 for light/pro, and 90 for pro).
I see, Thank you for your help.
