Hi,
sometimes - but not always - I've noted the the sync also sync's the recycle bin.
I sync the root of my drive against my backup drive (into a specific folder). During the sync I don't show hidden or system files (I only enabled it for the screen shot).
Is this a bug or not?
How can I avoid this?
Sreen shot:
Also after the sync DO does not stop "Reading contents of sub-folders ...".
I just did this with 10.5.2.5 Beta - but I know that both issues have happened also during the past (final) versions (and not always together).
Thanks a lot!
