Synchronize Questions
  1. Is directory synching between a library and a destination directory officially supported? If so, should Dopus highlight conflicts where there are multiple files of the same name in a source library directory (how does it know which one to compare against the destination directory)?
  2. In a multi-tabbed environment should Dopus be keeping track of which file displays it switched to checkbox/flat file mode after the comparison stage of a synch so that when the synch utility pane is closed it reverts those back? At present it seems to turn off checkbox/flat file mode in whatever file displays are active (which may be different from the ones changed during the comparison, as sometimes I switch to other tabs while a synch is happening).
  1. It'll work for some situations but if it's likely that there will be one like you describe then it's best avoided (as there isn't really a good way it could be handled). I would sync using the real member folders instead of the library in that case.
  2. Looks like a bug, thanks! We'll aim to get that fixed in the next update.
We've fixed #2 in the code now. We don't have a schedule for the next release yet, but whenever it happens that should be fixed for you.
