What happens if I try to synchronize a 64-bit version of a file with a 64-bit version?
Can you give more detail?
Sure. I try to synchronize the 32-bit version of the PDFXChange Editor with a 64-bit version.
That’s not a good idea. If you want to change the version of software, uninstall the 32-bit version, then install the 64-bit version.
Ok, I already thought this. Thanks!
