Tabs do not remember "view" setting
Hi,
I have my default view for all folders set to Details.
I have one tab open in details mode.
I open a second tab that duplicates the first tab. I then move to another folder and change the view to "Thumbnails".
Upon clicking and displaying the first tab, details view is changed to thumbnail view.
Is there any options for Dopus to remember that the first tab is in details mode and not change it?
What you're asking for is how it works already:
Have I misunderstood?
Hi,
Sorry, I didn't explain so well. That part shown in the video works fine.
The line that reads:
should actually read:
Upon clicking and displaying the first tab then changing to another directory within the first tab, details view is changed to thumbnail view.
You probably have the folder format lock turned on in the status bar. Turn it off, update your default lister (or layout, style, etc. if you are using those), then close the lister and open a new one and see if it works as you wish now.
Awesome! That seems to have done the trick.
Thanks very much. :slight_smile:
