Thanks super nice this is exactly what I wanted why this function is complicated here to activate it should be simpler Still Thanks
So you wanted to go into the folder in the current tab, and also open the same folder in a new tab, every time you double-click a folder?
That doesn't make any sense to me.
Before the tabs overlap I didn’t see the use now they are separated it’s better
I don't understand what you mean, sorry.
I think he's manually building a breadcrumb trail via tabs. So, his working tab is his active one, but the extra tabs are his history of folders.
But, that's pure supposition on my part.
That + the screenshot makes sense to me now.
But the path field gives you the same thing automatically, while folder tabs are better suited to other uses...
