Tabulator in info tip
Hi,
how add tabulator in info tip ? i want to align text and with space it's not perfect...
Thanks
Use \t like in the default menus.
if i write "\t" i have \t in the tip !!
Oh in infotips, sorry I mis-read the original post.
You can add these by pasting the tab character into the infotip. Copy a tab to the clipboard using a text editor.
Or press Ctrl + I
[quote="nudel"]Oh in infotips, sorry I mis-read the original post.
You can add these by pasting the tab character into the infotip. Copy a tab to the clipboard using a text editor.[/quote]
It's not simple... maybe a new request (add command in special fields menu...)
Yes thanks !!!!!
"Ctrl+I" don't work in DO9. it open import file type. :cry:
Seems so, I guess one of the keys needs to be changed. :slight_smile:
Copying a tab out of a text editor and pasting into the dialog still works as a workaround for now.
