I updated Teracopy on my system and now I see two sets of options (TeraCopy here, TeraMove here) in the right click, drag dialog. I do not have Teracopy in its default folder I have it in its own folder on a different partition.
I'm not sure how Opus is involved in that. Have you asked the Teracopy developers?
Before I updated there is just on set of tera copy/move selections. It seems like Dopus is picking up another set (maybe from a file that was not removed). I could just delete the orphaned file the Dopus reads to create those entries if I new were it was.
You updated Teracopy, not Opus. Presumably something changed in Teracopy.
Leo,
Yes, that is correct. I was NOT suggesting there was an issue with Dopus. I was saying there was an issue with the installation/update of Teracopy. What I wanted to know was where Dopus is looking to find the link to Teracopy. I am GUESSING there are two files where there should only be one. If I knew where (what folder) that was in, I could see if I could delete the duplicate and fix the issue. FYI, I have a good backup program (Reflect) so I just kept restoring the C drive (where the duplicate is apparently located) and re-trying the install of Teracopy. It didn't work the first time so I tried installing again. It took doing 2 times, but all is now correct - only one set of Tera copy/move selections in Dopus. I do appreciate how quickly you responded!! Thank you.
The right button drag drop menu items come from handlers listed in the registry, not from file links. Generally the two keys involved are:
HKEY_CLASSES_ROOT\Directory\shellex\DragDropHandlers
HKEY_CLASSES_ROOT\Folder\shellex\DragDropHandlers
Jon,
Thanks! That is exactly the kind of info I was looking for!
