Themes and toolbar background images not restoring
Hello,
I'm trying to make 2 themes, 1 light and 1 dark (for those headache days). I have a toolbar that lists my drive letters that has a custom made background. I told the theme to save everything (including images). For testing, I tried applying the saved theme and my custom background image used on that toolbar goes away. I have to edit that toolbar to get it back.
Am I doing something wrong? My image is saved in the dopusdata/images folder
version 10.0.0.2
Windows 7 x64
Thanks
How is that toolbar's background configured?
Like this:
Themes don't modify toolbars, so that toolbar will always look for an image called DOpus_Drives.png. Do both themes have an image with that name?
I haven't created my second theme yet. When I do, it will have a second image with a darker color. So I'm basically applying my saved theme on top of the same theme.
When I apply the theme and customize that toolbar, the check box is checked to use an image but the drop-down is empty
I'm not sure, to be honest. Themes have never worked very well with toolbars that use anything other than Standard Toolbar Image (or one of the other Standard* images) as their background.
No problem really. I won't be switching often and it's just a few clicks to fix. I just wanted you to know about it just in case it was a bug.
Thanks for your time Leo.
