Directory Opus 13.10.4 (Beta) Build 9060 x64
OS 10.0 (B:22631 P:2 T:1) SP 0.0
Busy spinner spinning forever.
Thought it was my new script - a simple folder navigation widget - to trigger it Click a folder in the list then back - repeat a few times.
Decided to check normal navigation in the lister doing the same thing (after a restart - which stops the spinner) and the same thing is happening.
(does not happen with folder that has no images)
Update: turning off caching also fixes the problem
