So, I have a Default lister folder format set to "Details". I have and a layout in which I try to use different folder formats (I'm unsuccessful so far for the past 2h).
One issue which I have noticed is that if I switch to Thumbnail mode when I'm somewhere in My Computer virtual folder and then I go to check out the Libraries folder, it has switched back to Details (the default) mode. And vice-versa. If I switch to Thumbnail mode while in Library, if I go back to something in My Computer it has switched back to Details. There is no such switch going on if I just browse in depth in these virtual folders.
I have no Favourites, Content, nor Path folder formats. I have unchecked almost all Folder Type formats.
So, what's going on? How I can force this separate layout to have specific, unchanging folder format (thumbnails mode), independent of the Default format?
Thank you.
