Hi. I'm using Directory Opus latest version 9.5.6.
Some images, not all, are in the wrong orientation in thumbnails view.
checked preferences, deleted all thumbnail cache, still same thing.
Thanks
Check that "use EXIF information to auto-rotate images" is turned on in the Thumbnails mode preferences. (Settings -> Preferences, then type EXIF into the filter at the bottom to find it.)
