Toggle left (or right)click/drag file action? (between move&copy)
I know that the default action, when a file is left-clicked then dragged to another place, is to move the file. Would it be possible to create a toggle , where the left-click/drag action could be changed to copy, rather than move?(and back again)
Thanks alot all you guys for the knowledge and help :opussanta:
Easiest thing to do is hold shift (move) or ctrl (copy) while dragging to override the default.
A toggle may be possible via scripting, although I am not sure it would work in every respect (the tooltips and drag cursor would indicate the wrong thing sometimes for sure, as the script won't run until the drop happens).
Alrighty Leo - thanks for the quick response and the help :open_mouth:
