Toolbar with Favorites?
Hi, I want to have a vertical toolbar at the right side of the lister where the Favorites list is displayed.
I created a toolbar and put a button on it, with this command:
Favorites SHOWICONS USEQUALKEYS
However, the toolbar displays the Favorites list with no icons!
In addition, I want the toolbar not to be set to the width of the longest Favorites path but to a custom width and the Favorites paths shortened by "..." in the middle. Is this possible?
Make sure the button's Show Image checkbox is set, and also that the toolbar itself (in Customize -> Toolbars) does not have icons disabled.
Not sure if you can change the width. I think if you have very wide paths then they will be truncated with "..." in the middle but if they are still too wide I'm not sure if there's a way to make the toolbar thinner, except by renaming the Favourites items. (You can do that without renaming the actual things that they point to.)
OK, I can adjust the Favorites names manually, as they do not change that often. I have a really nice (and useful) Lister layout now ... :stuck_out_tongue:
