Toolbars and Context menus (Video Attached)
I have had some success getting Windows Context Menus to display in a toolbar, however what I would REALLY like to be able to do is place some context menus into that are defined in the "File Type Groups" into the toolbar, a command along the following
FileType ContextMenu ContextForce FiletypeGroup = "Pictures" (Would place all context menu items defined for "Pictures" where I have placed the button)
FileType ContextMenu ContextForce FiletypeGroup = "Pictures" ID = 1 (Would place the first context menu defined for "Pictures" where I have placed the button)
I have attached a video to hopefully try and show why I would want to do this.
youtube.com/watch?v=qmSEPgRTGuk
Neat setup you've got in the video!
Using FileType CONTEXTMENU on its own will include any File Type Group items. I'm not sure if there is a way to get just those items, though, nor a way to make similar items which would only appear when certain types/groups are selected.
Might be worth sending a GPSoftware: Support Request to see if it can be added in the future.
Thanks! I appreciate that coming from DOpus guru :smiley:
[quote]Using FileType CONTEXTMENU on its own will include any File Type Group items. I'm not sure if there is a way to get just those items, though, nor a way to make similar items which would only appear when certain types/groups are selected.
[/quote]
Currently I have my right-click context menu defined in All files & Folders, so that I could get my context menus setup exactly how I wanted them.I have put all other Windows Context Menus into a sub-menu to try and keep it looking clean. Unfortunately this means using FileType CONTEXTMENU essentially displays my whole right-click context menu (not just those for a specific file type).
Ive got to thinking if there's any way I can possibly hack the registry to emulate what is happening with the WinRAR context items. If I could duplicate the winrar entry and then modify it for a particular file type to how I want. Something I might look into, but it's a bit messy.
I just thought I would expand on what I would like to achieve at the end of the day...
In the video, the sidebar "Common Tasks" is what I want to be displayed 90+% of the time. I dont want to be constantly switching between the toolbars to access other functions, as this kind of defeats the object of what I am trying to achieve, the other toolbars ("Miscellaneous", "Views" etc....) are just provided for completeness / less common tasks.
My vision is to have the toolbar's context area to display just the most common used items for a file type. This way all my common tasks (delete, copy etc) are always available as part of the "Common Tasks" toolbar, and also the most common tasks for a selected file type are also always available at the top in the context area. As mentioned above, this should mean I can spend 90+% of my time on the one toolbar.
Take pictures for example - I would setup a File Type Group "Pictures", define the following context menus....
Convert....
Convert to JPEG
Convert to PNG
Rotate Left
Rotate Right
Now for arguments sake, say I personally just use the "Convert to PNG" a lot, I would just put the command FileType ContextMenu FileTypeGroup="Pictures" ID=2 into the context area of my toolbar. I still want to have access to all the above items, which I can access by the normal right-click context menu, or in a new sidebar toolbar. This way, you dont loose any functionality, but the item(s) you use most often are automatically displayed and easy to access.
This could become really useful once all File Type Groups have been defined and the appropriate context menus made, making it simple to have easy access to you most common used commands. I can see things like ;
File Type	   - Function
Video		    - Upload video to youtube
iso files 	  - Burn to disc
iso files 	  - Mount Image
Audio files 	- Burn to Audio CD
etc...
It would also be really nice if the context area could be aware of cd-roms, and the content too, so for example you could provide these commands ;
Disc Type - Function All Discs - Copy Disc All Discs - Eject Disc Audio CD - Play CD Audio CD - Rip CD Audio CD - Display CD Text Data CD - Make .iso from disc
I know you probably realised all that anyway, but I just wanted to get the thoughts out of my head, and share with some one.
All the best.
That makes sense.
It could also be done by giving toolbar buttons a way to hide themselves unless certain file types/groups are selected.
Yes, I did also think this. If there was some kind of visibility clause that you could use to define when a button is visible. For the archive button I could define :
VISIBLE File = .rar
VISIBLE FileTypeGroup = Archive
Ive actually thought about this in the past as it would be quite useful. Some DOpus buttons come with this functionality already present, such as the thumbnail slider which is only present when the view is set to thumbnails, or placing a DRIVES button to only display non empty cd drives, will only display when there is a cd present in the drive. It would be nice to be able to mimic this for my own buttons.
I presume these buttons have this functionality hard-coded?
Yeah, those buttons are treated specially.
