Can i change a delay of the Tooltips popup to instant only for Directory Opus, but not for Windows?
For example its almost instant in XnViewMP (media browser) - first popup is delayed but next is instant...
Opus should also delay the first popup and then show ones triggered immediately afterwards without delay, when using the mouse.
You can also change the delay between holding Ctrl and an infotip appearing in Opus, but I think the mouse delays are part of the system-wide configurarion.
After all these years i was able to make a comparison video so you can see what do i mean. I should note that i was not able to record mouse cursor, but I held the mouse until the tooltip appears.
DOpus - small delay
XnViewMP - no delay
Windows Exporer - small-to-large delay
I think there needs to be some small delay, so you can move the mouse over files and land on the one you actually want without incurring a hit for all the files in between. (Tooltips can cause a bit of CPU/disk usage, depending on what's displayed in them.) But maybe we can make the delay even smaller or configurable. I need to take a look at the code.
