Troube with "location" path field
I still have troubles with the "location" path field (below the file and tree windows, where I can enter a path/drive etc.) when several tabs are used:
during the work with files/folders and changing between the tabs, there comes the moment where the location field no longer remembers the paths of each individual tab but rather shows the same path no matter what tab I select.
Had this problem in the old version, and nothing has changed so far for 9.0.0.4 (except the better style and selectable items of the path shown).
Didn't anyone see this as well? It's clearly a bug, all I need is to find a procedure how I can replicable.
Andreas
I've never seen this before. Next time it happens could you take a screenshot?
