Two feature questions
  1. When a directory has a lot of folders and I am in Details and I go into a folder and then out again, I have to scroll all the way back to the folder I was working on. Is there a way to simply automatically jump back to the point where I was?
  2. Is it possible to have the thumbnail toolbar by Nudel (or any other toolbar) automatically appear when DO senses that the folder has images in it?
Thanks
george
Hi there,
  1. After you switch from the first dir into the second dir, do not directly click on the first dir to get back to it... you'll need to use the Go BACK button on the toolbar.
  2. I don't think there is any display, layout, or folder format option in Dopus that remembers toolbar on/off settings. I believe they must be turned on and off manually...
Hi,
for the first, i use Go UP BACK instead of Go BACK. Go BACK use the history. with Go UP BACK, you go up to the parent folder and the folder are selected. If you navigate with folder tree, Go back select the previous folder in history.
:wink:
