Two preferences questions
  1. I'm having trouble disabling the Opus viewer for images (as opposed to using an external viewer). Where can I find that setting in Directory Opus 8?
  2. Is there a setting that does the following?...
    I have dual pane open and on one side I open a new tab (with an initially empty list of files). I want the focus to shift to the pane on which I've created the new tab.
Thanks.
Hi there... for the first, deselect the Use internal picture viewer for: option on the Preferences->Double-click->Files page.
For the second, how are you currently opening the new empty tab? It seems like there are a few ways to change the source/destination state of the file displays but I'm not familiar with any commands to affect the 'focus' or which one becomes 'active'... which is kind of surprising.
