Update to 10.0.4.0 problem
I try to update my opus from 10.0.3.0 to 10.0.4.0 and after that i have this message:
I already try:
  • re-download installation file (DOpusInstall64)
  • restart system and update again
  • uninstall opus and install clean version
any suggestion :question: :neutral_face:
Had the same problem.
You have to
  1. uninstall opus
  2. restart windows
  3. delete the program folder of opus
    3b) if that doesn't work, try "unlocker" (freeware)
  4. Reinstall opus
Dirk.
Thanks, delete this library dopuslib.dll works
