This is on a new PC that has never had DOpus installed on it. The only thing I did related to v12 is Restoring settings that I created using V12; however, I would not think that should not impact the Help | About window.
If that still reverts to Opus 12, are you using any kind of package / install management tools? Those can have their own ideas about which version you want installed.
Hi Leo,
Thanks for responding so quickly. I am not using any package or install management tools - just Chrome. I've downloaded the Opus 13 installer. Should I uninstall whatever Opus version is installed on my new PC? And, once I've installed Opus 13, can I use a config file (.ocb) from Opus 12?
Thanks, Ben
