Upload Speed very slow on 10.2.0.1 (4683) x86
G'day folks,
As it stands, the max connect speed here in Australia for uploading is 1000Kbps which in turn equates to an actual max speed of 100Kbps for the physical uploads of files and folders etc.
Calculating the 100Kbps less overheads is then, that I am able to upload between 68Kbps to 94Kbps on other servers, so what is the possible cause of the slow upload speed of 3 to 12Kbps using the FTP on Opus ?
Regards
pcbugfixer - The :sunglasses: Guy told me to ask this question.
What speeds do you get in other clients?
Thanks for reply Leo,
" ..... that I am able to upload between 68Kbps to 94Kbps on other servers"
Regards
pcbugfixer :smiley:
Other servers or other clients?
Have you tried other FTP clients to upload to the same server to see if there is a difference?
Thanks Leo,
The issue was fixed by re-booting the ISP service.
Regards
pcbugfixer :grin:
