USB drive volume names
The default name in lister is USB Drive and I would really like it to show the volume name instead.
Thanks in advance
Ian
It should show the name that Windows reports the drive as having.
What do you see in File Explorer?
Some drives don't trigger a refresh event properly when inserted and require a manual refresh (e.g. push F5).
Also note that if the whole Opus process is elevated then the refresh messages are blocked from reaching it. (This doesn't affect Admin Mode from within a normally launched Opus process.)
