I have one portable license for USB. How do I switch the device, do I just delete it on the current device and then export it again to the new one? How does DO ensure, that I use not more portable devices than the license allows, I suppose there is a certain procedure to follow (which I did not find described in the docs)?
Yes, that's all you need to do.
OK, thanks
