Use Text viewer instead of viewer for extension?
Perfect example. I turn on the viewer pane, then I click on an XML file and it tries to display it in what ever is registered for XML (which is usually the browser, which is worthless for what I want).
I would like it to use the Text Viewer no matter what the file is. If not the Text viewer, make it the binary file viewer. I don't want it to use the registered extensions to figure out how to view the file.
Go to Preferences / Viewer / Plugins and turn off any plugins you don't want it to use.
