Used card read drives not shown when hideempty is defined
Hi,
I always had
Go DRIVEBUTTONS=multifunc,hideempty
and when I put a SD card into my card reader the card reader drive letters will be shown.
With the latest beta (just using 10.5.0.3 (4808)) this does not happen anymore,
although the drive is in the "Savely Remove Hardware and Eject Media" list and selectable via explorer.
I've changed it to
and now all drive letters of my card readers are shown.
It looks like a bug in the latest betas or also release?
Maybe it's also possible to only show the drive letters of the card reader which are really in use?
It's possible your card reader (or its drivers) does not reliably notify the operating system when it changes between empty and non-empty.
Things which ask if it is empty will get the right answer, but things which rely on being told when it changes state will not know that their cached state is wrong and that they need to ask again.
