Using beta versions
Hi !
I'm a faithful directory opus user from many years now.
I'm used to always update to the latest "stable" version.
Now I'm wondering : should I update to the beta versions ?
I mean, do a take a risk if I update to the latest version ?
Do you have more intensive testing when you publish a stable version ? If yes, does this justify to wait the stable versions ?
Or should I always update to the latest beta build ?
What's your position and advice ?
Thanks
It's up to you, really.
The beta versions are usually very stable, but sometimes they contain bugs which are normally fixed in the next beta version.
[quote="leo"]
The beta versions are usually very stable[/quote]
it's all I needed to ear, thank you :slight_smile:
I will use beta versions from now on
