Using "Copy INSTALLFONT" recursively?
Sorry for feeling/being a bit dumb today, but I can't seem to get Opus to run a Copy INSTALLFONT command on the current directory with all subdirectories included in the search for font files.
Any tips or solutions for doing this?
I am afraid you need to look for fonts yourself, Copy INSTALLFONT is not going to do it for you. I'd use flat view and a filter or the FIND command to generate a list of fonts on which the command can work.
Do you think this could be scripted into an Opus function? I tried
Go "/My Font Archive/"
Set FLATVIEW=On
Copy INSTALLFONT *.otf
But it didn't work :confused:
Try
Set FLATVIEW=on
Select *.otf DESELECTNOMATCH
Copy INSTALLFONT
