Hi,
I'm trying to get Directory Opus to launch "File Locator Pro" instead of DO's built-in Find tool. I found an option that may allow this but I can't figure out how it works. The option is in:
SETTINGS -> PREFERENCES:
MISCELLANEOUS -> ADVANCED -> find_extension_func
I put the full path to File Locator Pro in that field but nothing has changed; DO still launches it's built-in Find tool. I tried the Advanced Keyboard Map option for the "Find" command but there doesn't seem to be any applicable arguments to launch an external find tool. Anyone have any ideas? Thank you.
