Using floated toolbar buttons to change lister directories?
Are there any additional arguments that can be added to the following path when defined in a floated toolbar button to help it use the last active lister window when more than two lister windows are open?
Go “C:\folder path”
I’ve been using floated toolbar buttons to open or change lister directories and they work very well for this. Even when another application like Outlook is the topmost active window, I can still change the last active lister’s directory without it opening in a new lister window. This works fine with a dual lister as well. It still remembers the last lister window used and changes that lister window to the target directory. However, when there is more than one lister window open, dual or single, this stops working the same. If another application like Outlook is topmost the toolbar button no longer remembers the last active lister window and opens the target directory in a new separate lister window. So, is it possible to have this same functionality when more than two lister windows are open?
Any help appreciated!
