Using split view, how can I set / reset both locations to a specific folder / location?
Using split view, how can I set / reset both locations to a specific folder? For example: D:\ and E:\ drives. This is useful for when I'm done navigating / handling files to go back to where I need both locations to be in.
Sorry to ask. I normally search, but I don't seam to find the proper terms.
I also tried making a button, but I don't see a way to specific a specific split a specific location so what ends up happening is that 1 side goes to D:\ and then E:\
You could use a Folder Tab Group to do that, or a command like:
Go "D:\" DUALPATH "E:\"
Bingo! Thank you LEO!
