Using the "home" alias to specify icon location
For some reason the "home" alias doesn't seem to work inside the dialog for assigning icon files to toolbar buttons, though it works everywhere else. (I'm trying to take my icons with me when I run Directory Opus from a thumb drive.) Is there a workaround?
What version of Opus are you using?
It seems to work fine here in Opus 12. I have a feeling it may not have worked in older versions.
It's version 11.
I noticed the same thing on v11.19 when I tried to portabilize. Was there ever a fix? I'm reluctant to upgrade just for that one bugaboo.
As I said, it works in Opus 12.
Figured out a workaround, though it's a PITA. Create a custom Icon Set, import it, reassign those icons to their buttons using the Icon Set (where they were previously associated with external files before), and then do a Backup Configuration of the entire DOpus install, making sure the "Backup Images" option is checked. Then do a one-time Restore Configuration into the USB DOpus and you're good to go.
