This problem is a bit ridiculous. When two persons like to use Directory Opus on one machine and if one perfers the Light and the other the Pro Version then he/she must always use after logon the licence manager to switch to Light or Pro and vice versa because the licence is stored globally in /dopusglobaldata.
Can you add to the file "userdata.omd" to "beta_warrior="yes"" and "config_type="private"" etc. another value like "licence_type="light/pro""? Because then the licence is stored additionally in this file and the exhausting process of licence switch can be dropped.
And my second question is: Is the Light version included in the Pro Licence or not?
Thank you!
