V13 titlebar showing '0'
Version 13.1 title bar has not returned to normal after updating from beta version.
What does it show exactly?
Do the settings in Preferences / File Displays / Title Bar look correct?
Any script add-ins installed that change the title?
did delete some inactive titlebar scripts that I was going to modify, did a restart - still not back to normal. I'm guessing it's one of those 'only happening to me' things, Any way of resetting it without doing a reinstall ?
(Disabling all scripts does not fix)
Set LISTERTITLE should reset it.
awesome - many thanks, back to normal :slight_smile:
