Vertical Scroll Position default
Consider the lister when I navigate to this folder as shown:
As you can see the vertical scroll bar by default places the lister at the top of the folder.
Is it possible to change this default so that the vertical scroll places the lister at the bottom of the folder instread.
So it would look like this:
I am aware that you can reverse the sort order and I am experimenting with this.
Thanks as always for any help.
Searched forums; Looked in help, Looked through prefs dialog, checked FAQs
No, it's not.
Dam. Finally something Opus does not do :slight_smile:
Thanks Leo...
