For some reason, I can no longer get my FOURCC column to display codec information (HEVC etc.), the Data Rate column to display its kbps video-file information, and the Bitrate column to show its sound kbps information. All other video-information columns (Dimensions, Duration...) display information properly.
I use the ADVANCED_Codecs_v779 installation using all default settings so I can play my HEVC files in Windows 10 without issue, but over the past week after updating to this latest version as of 26th June, this is when the aforementioned information has disappeared and stopped being displayed.
It may well just be a setting in this software, but I can't locate it or know for sure, even though this seems the likely culprit. Any suggestions to resolve this issue would be very much appreciated, thank you, as it is DOpus (the latest 12.6 version) that is clearly being affected by this.
