Viewer for 64 bit error
I've been trying unsuccessfully to install the 64 bit activeX plug in "setup_dopus9_32bit_activex_3_0_0_3" without success. I keep getting the error
" Director Opud is not installed properly in this computer n%n% you must reinstall or install Opus before attempting to install this plug in"
I've tried uninstalling and reinstalling without success. The computer is running Vista business. Any help would be gratefully received.
Er .... that filename you're quoting clearly says 32bit. Try downloading the 64bit version.
(I've moved this post to a more appropriate forum)
My apologies. The file I'm trying to install is definately the 64 bit version
setup_dopus9_64bit_plugins_2008-03-12.
The plugins (except NFO) are included in the Opus 9.1.0.4 installer so you don't need to install them separately anymore.
